Potter raised the deck an inch or two in about 74 when he changed from the 4 stringer to 2 stringer hull, so I think you'd be ok, but easy enough to just pull the plugs and check. Double check to make sure PO did not install drain holes in the step down.
My bilge pump is wired direct to my dual purpose battery with an in-line fuse so it will run even with Battery switch off.
