Old 06-14-2016, 09:29 PM
Jeffro, It looks like you might be able to put a 3" or 4" aluminum angle across the transom just under or above the fibergalss transom stiffener that is already there. If you can "catch" a couple of the bracket or engine bolts that's even better. Have someone weld a couple of 4" X 6" end plates on the ends of the angle and through bolt them to the sides of the transom well with some backing plates on the inside of the battery boxes. That should hold you until the fall and don't forget to trim the mushrooms off if the grow up through the crack - we have our "standards".
Come on Terry, you know the drill--------> 1974------> 40+ year old transom. The transom is shot, period.
Jeff,Don't spend a bunch ching into temporary fixes. Removing the motor, rigging disconnects, bracing metal plates etc etc etc.....bite the bullet dude, it's time.
Think safety first not another few rides while I can.
Sorry just my 2 cents, what the hell do I know anyway, I don't even own a SeaCraft anymore......Good Luck in your decision.
