Originally Posted by Spruill242
Yeah I'm happy. Combination of prop and tabs really makes a difference. Would like to raise the motor up a hole but that's just being nit picky at this point.
Boat got on plane very quick. Less harmonics at WOT. Can level the boat out as needed to vastly improve ride.
Basically I'm a believer. Put the time in to get your prop right and get tabs on the boat. Very worth it.
Raise it, you might be even happier. The right set up will make a good hull perform correctly. Pitch and diameter of a prop matter but rake, cup and blade design will dramatically effect performance also.
