Old 07-30-2016, 10:27 PM
Default Tested Prop Characteristics
Sorry McGillicuddy, thought I had included the prop characteristics of the tested props. Here they are:
HIGH FIVE Stainless 5B 13.5" X 17"P
5 degrees trim, DAY1 5630 40.7
6 degrees trim, DAY1 5680 40.2
POWERTECH 4B 15" X 15"P
5 degrees trim, DAY1 5340 38
6 degrees trim, DAY1 5380 38.5
CYCLONE Stainless 4B 14.5" X 15"P
5 degrees trim, DAY2 5280 40.8
6 degrees trim, DAY2 5330 40.8
Black Diamond Aluminum 3B 14.5" X 17"P
5 degrees trim, DAY3 5420 41.1
6 degrees trim, DAY3 5530 40.1
Vortex Aluminum 4B 14.0" X 18"P
0 degrees trim 5250 36.3
5 degrees trim 5390 38.3
Recorded RPM and speed were digital from a GPS PerfectPass gage. I can set the desired PerfectPass RPM which holds steady within about +/-20, then record the attained mean speed at that trim angle.
My typical operation is between 0 and 5 degrees trim, at 6 it starts getting hard to steer. Sometimes start trimmed down for the accel particularly for slalom and footing, then trim up after planed out. All tests were similar conditions and all without towing anyone. Sometimes flatter water than other days. The Black Diamond cavitation (don't remember trim angle) also not towing anyone. Once again for my routine operation at watersports, the High Five is good. The Cyclone might have been a good cruise prop if it were tweaked a little with a smaller diameter or lower pitch to increase the WOT RPM. Cyclone WOT speed was good, just not revving high enough.
