Old 08-09-2016, 10:40 PM
Skeeter15 Skeeter15 is offline
Thank you for the feedback. My props rotate outward. I will move the lower units back toward parallel looking for the sweet spot. Disconnecting the cross bar did not work on my boat. The loose engine would turn inward approximately 1 inch and ventilate like crazy. Boat had difficulty planing. I think it is because there is a hull transition directly in front of the lower units causing them to act a little different. The boat performs well with the slight toe-out. Just trying to maximize efficiency. Thanks.
