Old 08-17-2016, 05:07 PM
76Red18 76Red18 is offline
Starting circuit wires as mentioned. My key switch would intermittently cause a loss of power. Had to replace it. Check your power pack ground wire. Black wire from pack to a coil mounting bolt. Clean both fine pin connectors at the top of the pack with alcohol or degreaser. NO dielectric grease or anything else on those on those connections. If the power pack is original, it could very well be failing. It can be troubleshooted with a manual and the right test equipment.
J. M. Hendrix
