Originally Posted by natecert
Talked to Huge yesterday since I had not heard back from Tom regarding the max power and top end for the hull. Oddly neither Hugh or Tom were familiar with the variable dead rise hull.
Also will be getting advice on where to buy the boards IE: coosa, divinicell etc.
That is true. Tom only knows what I told him about as far as ride characteristics. He was surprised when I told him at wot, the water breaks from the hull more than 2/3's of the way back from the bow. He also made a comment about lift; being able to pick up 3000 lbs of v-hull that high with only 150 hp. We also discussed external transom mount bait wells and following the contour of the hull. Follow the contour and make the rear of them with 1 or 2 degrees negative "trim".
