Old 10-10-2016, 03:17 AM
natecert natecert is offline
If the kicker can be locked into a straight position then I believe your correct about steering with the main motor.
I have the next three weeks to skin coat 11 boards and some final tweaks to the lay up table. Its just is not as rigid as I want it to be. My thought is the final product will only be as good as the lay up table.
Made it in two pieces 22" wide and 1/2 thick with 1/2 X 3/16 aluminum stock on the edge. Have 2 saw horses and will try adding a two more.
Quick question, can I use peel ply over the lay up and use a roller to squeeze out unneeded resin?
