Old 10-10-2016, 10:09 PM
You asked for our .02--- how about the 292 you mentioned.Clifford research four barrel intake. get with Holley and I'd bet they could set you up with a throttle body fuel injection system then upgrade
to a electronic ignition system and I wouldn't think mercury' 250 hp number would be hard to achieve .you could get with Clifford and see if a cam is needed to match what Mercury was using ?
Thanks, wattaway. I am very intrigued by the gm 292 idea. What about the sterndrive? Any insight on compatibility? My understanding was Merc only mated it to a Mercruiser II. Do you know of requirements to to make it adaptable to more current drives like Alpha, Bravo, SEI? Simple as a transom plate and gimbal housing? Would it require a particular gear ratio? I'm very excited to learn more.
