Thread: hydro shield?
Old 11-04-2016, 07:56 AM
cdavisdb cdavisdb is offline
Hmmm. This sounds like a vertical CG issue, probably related to using an outboard. My I/O doesn't act like that at all. The outboard will have a high vertical CG. The 25 Seafari has a fair amount of cabin weight up high anyway. The 25 Hydosport is the same thing, relative lot of cabin and hull weight high plus a very deep, slab sided deepV.
You would think that a full load of ice and fuel would pretty much counter that problem. Does the boat act better or worse when its light? Some CG calculation(see above) seems like a good idea.
