Old 11-08-2016, 02:29 PM
Originally Posted by TPG View Post
Who has gone what?
Poly folks, I see the 52 gallon Moeller would fit nicely under deck. And at $350 I'm sure significantly cheaper than aluminum.
Talk to me!
Moeller Belly Fuel Tank, 52 gal., 24"W x 60"L x 10"D
If this is the one you're refering too . . . I see the following problems.
Fuel Fill Height and location . . . Stringer width is almost exactly 24" on the 2 stringer seacrafts and 22 - 23" on the 4 stringer versions. Assuming you have a post 72 - 2 stinger 20 seacraft . . . The width won't be an issue until you factor in the bend you need to make with the hose attached to the fuel fill. You might be able to get creative with a 90 degree elbow, but I wouldn't bet $350 on it.
Height - I think when you factor in the fitting height you'll be really close. You might be able to push this tank forward and gain the needed height for the fittings including the fuel fill.
