It might be leaking through the bolt holes since its not through the plug. I didn't see any seepage on the inside of the transom bolts but that doesn't mean it won't happen. Is it possible to take out one bolt at a time and properly seal without taking off the entire bracket and motor? That's something I could do otherwise I have to pay someone to do it. I was thinking I would seal the entire pontoon properly which would, in theory, protect the bolt holes within the pontoon from any seepage. I can easily take out the 4-6 bolts running the length of the platform and properly seal those because they are easily accessible inside and outside of transom. Then, maybe seal the length of the platform also? Good thing is it's only been out for a few short rides but it's apparent that after sitting in the water for a while it gives it enough time to fill that pontoon.
Thanks for the help!
