Old 11-19-2016, 10:33 PM
GameOnSalmon GameOnSalmon is offline
1.5 inches on mine with a 10' bracket. The boat you bought was well set up and squeezing about all you're going to get out of it. Also the Zukes hate Rev 4 props and most all Merc wheels due to their smaller diameter and blade surface area. Gearing n Zukes is way different then Merc and they need big wheels. A full rigged Tsunami is not going to be as fast as a 23.3 Formula hull. I owned one and am very familiar with the differences between the two. With the same power and props the Formula was 4-5 knots faster, mostly due to weight.
Moose thank you for the input. I have read up on your Posts in regards to the 300 and the Powertech Prop. The zuke wheel just sucks performance wise, probably being the reason you went with the LFS Powertech. Mainly was trying to alleviate a bunch of testing with a slug of props.
Figured i could Probably run a 21p Rev 4 and then have Rich Work his magic on it to make it hit the Rev Limit. Right now i have on the 16 x 18.5 honestly just not impressed with it. Even at my elevation about 3500 feet i am usually 300 RPM slower here than sea level its pulling 5900 RPM and the Hole shot was sluggish at best.
Thank You for the Input... I am going to look into the LFS and perhaps Demo a Rev 4. Totally agree about the Gear Ratio being so much different.
What hole are you in?? Can you post a pic??
I have 3 Holes i can move it up. About 2.5 Inches. Right now with 30" of setback its just about 4 Inches above the Keel... I think i am just going to Jack it to the Top and See what happens. If its Close... Then i can start messing with some props.
As always i much appreciate the Input from everyone.
