Old 12-17-2016, 02:31 PM
Joe R Joe R is offline
My 21 cc hull 1998 year has the same thing ...the fwd bilge collects water as the deep v is low in this part of the hull, even with a 500 lb motor...there is a pvc pipe that gos from there through the fuel coffin to the aft bilge and you have to run with the bow way up with the pump on to get the water to run through the drain pipe to the aft bilge....I think I am going to put a pump up there . boat is slipped so there is water up there often...I also have a pie inspection plate to check this fwd bildge..
Joe R.
21 SeaCraft
1998 w/200 Optimax
Susie 2
Joe R
