Old 01-27-2017, 05:39 PM
linesider36 linesider36 is offline
When FAS redid my transom on a '79 23' I cut away the outer skin like you did but FAS cut the cap on either side of the motor well so he could slide the sandwished marine plywood and glass into the hull as one piece. It doesn't look like you'd have to cut much to do the same. Also save your hull Number!!! Just a thought. Good luck with it .
