Originally Posted by rmayo jr
Distant relatives lol, I was raised in Mesic. The boat is owned by a farmer in Alliance, palm beach style hard top, dark blue hull sides. One thing I dont trust is the factory Zuki analogue gauges, plan to swap to digital SIMs connected units to get a accurate rpm off each motor then go from there. I'll report as I progress, thanks
rmayo jr
If you are from Mesic, then you defiantly get the "down in the county" phrase lol
Where your at with the props don't sound bad. You may could prop it more but running out of the turning basin (Morehead) offshore your only going to be able to run it flat out on select days...Planning at low speeds may be more important. Understand both sides. When you gotta run 60 miles out to hit the break its nice to be able to get there quicker.
