Originally Posted by manitunc
What performance should I expect from a 1974 20' SF with a 2011 Evinrude Etec 150 on a bracket. looking to replace my flats boat with a Seacraft for inshore and some offshore fishing, but would like to keep a 40 mph cruise speed and low 50s max.
You must be used to boating in flat water if you expect to run those sort of speeds. Don's right, typical offshore conditions will not allow those kinds of speeds in a 20' hull unless you want to be airborne most of the time! The 20' SeaCraft hull is built like an aircraft with hollow fiberglass stringers tied together with balsa cored decks, so it's very strong but relatively light. You'll find that it will start to go airborne at about 20 kts when seas get over about 3'. A Bracket may add about 3 mph in top speed, but because it shifts weight aft, the ride in rough water will be worse and I'd expect it to get airborne easier. If you run a bow-lifting Viper prop, and don't have a T-top, you might see upper 40's in flat water, but your low speed planing performance will suffer and you won't be able to hang on plane below about 20 mph. A 4B Cyclone prop is much better for offshore use and should let you hang on plane down around 12 mph, but you'll sacrifice some top speed. The 20' SeaCraft hull was designed to run 20-30 mph in rough water, not 50 mph in flat water, so maybe you should be looking at a bass boat.
I had mine up to 50 mph one time with the top down and a very light load in a light chop and it chine walked enough that it would have thrown me out of the boat if I hadn't been really hanging on! At that speed, the outer panels of the hull are completely out of the water, so it's not very stable.
I've made the 160 mile run over to the Abaco's a half dozen times, and even with very heavy loads in the cabin, which significantly improves the ride, we did well to hold a 20kt cruise in the 2 ft square waves commonly encountered on the Little Bahama bank.
