Originally Posted by SailorChlud
Gee - a 2" PVC tube takes up some space under the starboard gunnel. How did you mount it to avoid it interfering with the rod holders through the deck cap?
I think it might have been 1.5" OD - I believe it was actually some sanitation hose I found at a local marine surplus store, so it was more flexible than regular PVC pipe, but there was not a lot of room inside it. I was able to fit it up into the inside of the raised coaming next to the gunnel. If you could heat some PVC pipe with a heat gun enough to soften it and squash it into an oval shape, that would probably be even better.
