Old 03-22-2017, 07:47 PM
run 1000 gallons of water through the tank (whatever it takes). Drill a bunch of small holes down the back side while the tank is totally full of soapy water while there are no fumes. Let it drain and air out and then saw away. If it smells like fuel rinse and repeat.
Yup.
Put a hose in and walk away. Lots of degreaser and Dawn.
You can cut the wide flange back. You only need an inch. You can fill the holes with
resin and cabosil/ chopped strand. You want the coffin water PROOF.
The GE pure silicone caulk will hold the coffin cover tight and fast.
Use a lot and put some 80 or 120 mono in tight so you can open her up like a zipper
in the future.
