Is the deck soft?
Is the replaced deck wood or composite?
Why will the deck need to be repainted?
Any cracks in the fiberglass?
Any repairs made using wood? If they had the deck up then they may have modified the stringers.
Was closed-cell foam used below deck?
Does transom give when you push on it?
Is the transom wood or composite?
Are the hatches soft or warped?
Are the hatches heavier than they should be (waterlogged)?
Are thru-hulls plastic or metal?
Are thru-hulls properly sealed?
Do rod holders give any when you wiggle them?
Do you see any rust stains?
Any moisture or mold in any compartments?
What is the thickness of the metal of the replacement fuel tank?
What fuel tank foamed in or attached in some other way?
Was the fuel tank coated in coal tar to prevent rust?
You need a trailer. You need a newer engine with controls and gauges if you plan on running offshore. If you don't have to pull up the deck or replace transom and the hull is good shape then I would hazard a guess that its probably worth between 3 and 7 grand. Around here that engine could be resold for about 1000 or 1500 if it checks out OK. It would end up on a crab boat.
I wouldn't include another person's rewiring job into the value of the boat. Its nothing personal. I just assume I will have to redo it myself. The vhf is probably OK for a while yet but that 5 year old GPS may need replacing soon.
