Thread: My FICHT 115
Old 04-30-2017, 11:03 PM
Originally Posted by TomParis View Post
. . . Anyway here is a picture of my plugs they looked pretty fouled to me.
Not sure about a Ficht but that's normal for an E-TEC. Really nothing to worry about as they still run fine like that. I'd try to get a factory service manual if you don't already have one. Factory recommends also replacing nylon washers on drain and fill plugs when changing gear oil.
Disconnecting the shift linkage on my E-TEC was easier than on my old 115 carb'd motor due to good access to everything when lower shrouds are removed. Once you have lower unit off, take it to dealer and have them perform pressure and vacuum tests on it to determine if you also need to change the prop shaft seals or the upper seals below the water pump. There is a spec on shift shaft height, which should be checked to insure no shifting problem after installation.
