Originally Posted by kmoose
Rob, What kind of performance #s are you getting on your V-Rod powered Scepter? It would be interesting to see how they compare to what I and others are getting.
Ken,
Right now i have a worked Powertech OFS 4 blade has some extra cup in it and its a 18p. Top End is 56 mph with a cruise of 4000 RPM's i am getting 37 mph burning 11 GPH. If i run much over 4000 the Gas Really dumps.
I tried to prop this for max cruising potential so monkey around with the engine height a lot and then propping. I don't have enough time on it yet to make all the tweaks.
Be taking it to the Coast in about 4 weeks..
Also keep in mind that is with the Simon Motorsports PCM Flash. I will say the Power curve delivery is way better with the simon mapping that merc ever thought it would be and a Hell of a lot more Torque across the band.
Also i am still waiting to find a 17p Rev-4 Prop turn it then send it off and get it worked as well and see if it will do better. I mean the numbers are great but i think there is still room for improvement.
Robert
