Old 07-11-2017, 02:21 PM
NIPPAH NIPPAH is offline
I like to do it from the inside and think it is a better way myself but it can be done both ways and still be plenty strong if done correctly. I just like to leave the original hull shell in tack if I can. Also its easier to add thickness to it as well. The biggest advantage is there is way, way, less fairing.
If you want to do composite, Coosa is hard to beat but there are others that will work too. NidaCore will crush in under pressure from engine bolts so I wouldn't use that tho.
Height, I always add a few inches to the transom. Normally shoot for 26.5-27 so the outboard can have plenty of adjustment moving up to get the av plate out of the water while under way.
Just wants to thank you for the input. We went ahead and used marine grade ply. It was a lot cheaper than the Coosa. I am glad that we re-did it bc we were able to check out the stringers and they are not soaked at all so that was very reassuring. I am going to add some pics to show our progress.
