Old 07-27-2017, 08:05 AM
Wildfire Wildfire is offline
I am not familiar with the Evercoat Patch system you are using but it sounds like it is thickened gel coat. If it is then the pin holes you are getting is from the gassing produced by the heat created by a relatively thick liquid. We do these repairs all the time. This is our method. Use regular white gel coat
(not thickened with no wax added). You can use the tints you already have to get your color match. Once you have your match you mix your gel coat one to one ratio with Duratec High Gloss Additive. Both the gel coat and Duratec can be purchased at any good fiberglass supplier. Thicken the gel coat into a paste by adding some cabosil., add your hardener and apply like body filler. It will shrink a little. After sanding with 100 grit repeat the process. If you are satisfied with the finish, final sand with 220 grit going out a few inches past your repair. Harbor Freight sells a little 4 oz gravity feed paint gun for about 13 dollars on sale. If you plan on continuing to do your own touch up work this gun is the best 13 bucks you'll ever spend. Mix another batch of gel coat and Duratec the same ratio. If your base repairs are a pretty close color match then you can reduce your gel coat with lacquer thinner another 10%, ( thinner also cuts down the hiding ability of the gel coat) add your MEKP and paint over your repairs out to the edge of where you sanded. Get rid of the excess gel coat and put some more lacquer thinner in the gun. Spray a little out to clear most of the remaining gel coat from the gun, then spray over the outer overspray ring to help melt it in and reduce the amount of sanding later. After curing sand the remaining overspray down with 400 and then 800 grit and finally with 1200 for light colors, 1500 for darker. Buff out with the compound of your choice. We use 3M Perfect-it extra cut, it is a bit pricey and only available at automotive paint suppliers. Because of the line edge on most gel repairs, unless you get a perfect color match you will always be able to see the repair. By spraying your final coat even slight mismatches will usually blend in enough so that the casual observer won't see it.
Good luck
