Old 08-17-2017, 09:18 PM
bigeasy1 bigeasy1 is offline
Not sure if this helps but I had a similar problem with my 1974 Tsunami.In my case it was globs of Potter putty that basically blocked up the area of the fuel tank forward of the I/O motor box.
The putty was so thick under the tank platform that it prevented any water from getting to the transom drain.
I had to use a small crow bar hitting it with a 3lb hand held drilling (sledge) to break up the putty.I have to say that it was some damm tough putty..Ground up the rest with a combination of #24 grit fiber backed discs on my disk grinder, and a bunch of long shank drill bits.I glued in some pvc drain tubes on each side of the keel under the new tank platform.
Water drains nice and quick now.
All this,just for a boat ride
