John, thanks for the advice, i cut it at 26 and a quarter today. Unfortunately a large portion of the transom was wet, so i stripped the transom interior ply and removed the two seats and old IO ingine box, flush cut all the engine box coaming and am preparing to make template in the morning to relaminate the transom with two layers of 3/4" marine ply. Im also goung to glass in two knees coming up from the main stringers which will sit just outboard of the OB mounting bracket/bolt configuration. The knees will be incorporated into a splash well, once i get to that point. Im planning to put two pieces of ss plate on inner and outer transom to bolt through after decoring the engine hardware holes and filling with hull and deck. Was really hoping the transom would be moderately intact but not the case. I cut the notch 32" wide, at the top, tapering to about 28 where the OB will sit
