Old 08-31-2017, 10:41 AM
Yachtie Yachtie is offline
Originally Posted by Basketcase View Post
While redoing the stringers on my 20, I cut a section off a hollow fiberglass shovel handle and glassed it in the hole. Worked out well. You may drain the standing water out of that stringer, but no amount of fanning will "dry" it out, unfortunately. Once that foam takes water, it doesn't like to give it back.
That's what I figure. Also seams to be a big glob of foam on the outside of those stringers, in the outter bilge. Assuming it was out there for deck support? It's soaked as well.
Wish I had the budget to pull the decks and deal with the wet foam, but not in the cards right now.
