Old 09-05-2017, 08:15 AM
You got more projects going than I could handle, but that is one that would really pay dividends if you can get it in the water. Its an amazing hull. An I/O works best, but I bet a 350 outboard mounted as low as possible and on the transum would work real well too.
I have twin 200hp 2.5's (under 400lbs each) to hang on the back of her. I built molds for a super short setback bracket to be able to keep the full transom in the rear. Don't know if that will be an mistake or not as I probably should hang them direct on the transom. Hoping the counter rotators will help with the rolling issues but also plan on doing big tab modification like Blue_Heron.
