Old 11-08-2017, 06:06 PM
I just helped my neighbor take his 26' Mako off his trailer last weekend and block it up so he can take off the bottom paint, a lot more fun than a 20' SC. As luck would have it he has a flat chine 6" wide at the transom forward to place the rear blocks. Get the stands close to the transom on the flattest (horizontal) place as possible. The transom is the strongest point so you want the stands there, the front stand should go about where the roller is on your trailer. If you are going to use the stands in the pictures, for safety I would get a strong ratchet cable/strap and tie the rear stands in position from sliding outwards. Good luck!
