Old 11-18-2017, 08:46 PM
ssscotty ssscotty is offline
i had a similar issue when i had the 74 sceptre, i took one side of a motor ear muff hooked up to the hose and put it over each deck drain thru from the underside of the boat... and sure enough one side allowed water entry. i ended up re doing them with a heavier duty compression fitting. problem solved.
