Old 11-20-2017, 05:31 PM
FLexpat FLexpat is offline
In that case make sure you replace the wooden blocks around the scupper holes while you are at it - mine leaked pretty bad and I also had corrosion holes through the original I/O transom housing and the exhaust Y pipe pretty much fell off while I was removing it. I didn't know it was that bad when I started, but I found out that everything in the stern was basically toast - even the U bolts...
