  #34
Old 12-08-2017, 08:51 PM
Great
FYI.....I think this is very similar to Arjay 6011, if not the same.
Pourable Transom Compound Carbon-Bond Formally Nida-Bond
CARBON-BOND POURABLE TRANSOM COMPOUND is ceramic filled
polyester exhibiting exceptional physical properties. In particular,
the compressive strength has been documented by an independent
testing laboratory to be 3,895 psi (ASTM 695). This is several times that
of plywood and 8 to 10 times that of PVC foam. In addition, the failure
mode shows elastic yielding before failure. This makes the CARBON-BOND
POURABLE TRANSOM COMPOUND material an excellent choice for
critical applications such as coring transoms on power boat hulls.
You chose wisely.
