Old 01-11-2018, 11:54 PM
Rybones Rybones is offline
Originally Posted by JBASS02 View Post
I have a couple of questions regarding transoms.
1. I had read on another thread that people were recommending building the transom at 26" instead of 25", is this typical?
2. If I install two bilge pumps, one at hull level and one elevated, do I need a drain plug? The only thing that will be draining into the bilge will be the anchor locker. It seems like if I get a little water in the bilge I can just pump it out. Not having a drain hole would be one less thing to forget/maintain.
3. I've read several post where people use side scuppers rather than transom or the original thru deck. What is the advantage to this?
I'm trying to finalize my transom design any thoughts or recommendation are always welcome.
I've also posted and been reply to in this regard. Some saying 26 some saying even 30. I'd like more clarification on the 30. I like what you are doing, I have a lot of the same work to do to a 74 I have. Currently it's completely usable without the fear of catastrophic failure, but they're soft spots in the deck and one side of the transom has an eerie Hollow sound to it when knocked on. Although in my case, this isn't something I need to address immediately, but the check is in the mail.
