Old 02-14-2018, 12:42 AM
Rybones Rybones is offline
Hi PackRat, , you did a fantastic job. I have a 74 20 also. The colors on yours look like what I have been looking at for mine. I thought I read that you used Awlgrip, but it looks lighter than the Seafoam, what colors did you use inside and out?
Also see that you raised deck and put through scuppers in straight to the transom, do they drain well and do they let water in when standing in corners of the boat?
Ok, last question looks like you went with e Simrad Go7. (I did) Did you need to buy the flush mount kit? I have the same console as you and have mine mounted on the bracket provided, were there any tricks to the in-dash install, did it fit just fine? (I thought the power cord and transducer cable would stick out too far to fit..?
