Old 02-15-2018, 01:34 PM
PackRat PackRat is offline
Rybones,
See photos below:
Photo is rotated 90 deg CCW....The deck top surface is about 3.5" above the water line and the water line is about 3.5" above the chine at the transom for this boat. The drain tube was a fiberglass 1" ID x 1.25" OD that I angled down to make room for Rabud diameter below the bracket flange. Size was kept small to fit inside Rabud scupper diameter but I never installed.
I told you a wrong number - the starboard panel was 3/8" thick, not 1/4". I installed a 1/2" panel inside console to screw all the electrical components to so that took up a little room as well. Don't think you will have a problem fitting it in. Don't judge me too harshly on wiring as did not button all that up tight just yet as might add a few extras this spring , 12V power receptacles , etc. and need to route some wires.
