Old 02-28-2018, 08:53 PM
RoomToMove RoomToMove is offline
We got a little work done with the warmer weather around the past two weekends. Boat is now covered in a tent. The make shift "shop" keeps it protected from the elements and gives us the ability to crank some heat if we need it.
Name:  craft in tent upright.jpg
First, we removed the casting platform. Then, the entire belly and stringers were ground down for a better bonding surface. Lots of hours with the grinder and disc sander. Snapped some lines cut open the stringers and removed all the foam/water. About 2-3 inches of foam in there, suspended off the hull.
Any recommendations on a foam to use (and where to buy) for raising the stringers? Need it for reshaping the void and then raising 2.5". Trying to stay away from divinycell because of the $$. Looking for something like billythekid used in his build. Trying to use poly on the stringers but heard it will melt some foams.
Cheers
Name:  stringers forward.jpg
Name:  sting port 0.jpg
Name:  stringers star 0.jpg
