Originally Posted by RoomToMove
We got a little work done with the warmer weather around the past two weekends. Boat is now covered in a tent. The make shift "shop" keeps it protected from the elements and gives us the ability to crank some heat if we need it.
Attachment 16721
First, we removed the casting platform. Then, the entire belly and stringers were ground down for a better bonding surface. Lots of hours with the grinder and disc sander. Snapped some lines cut open the stringers and removed all the foam/water. About 2-3 inches of foam in there, suspended off the hull.
Any recommendations on a foam to use (and where to buy) for raising the stringers? Need it for reshaping the void and then raising 2.5". Trying to stay away from divinycell because of the $$. Looking for something like billythekid used in his build. Trying to use poly on the stringers but heard it will melt some foams.
Cheers
Attachment 16722
Attachment 16725
Attachment 16726
Where’d you get that tent from? I want one!
