Old 03-13-2018, 07:34 PM
RoomToMove RoomToMove is offline
that is the straightest I have ever seen someone cut the stringers open, holy cow. I used a peice of 2" dyvinacell to raise my stringers on the third one , number one and two I just rip strips of marine plywood and glued and screwed them together then glasses them to the stringers. I think 1 sheet of 3/4 marine ply ($120) will do all the stringers. if memory serves me they are 3 " wide. I think I stack 3 pieces on top of each other. dont waste your time or money on the hard foam from homey depot it has no strength at all.
Thanks Billy-- sometimes it better to be lucky than good. Hopefully the fiberglassing comes as naturally as the grinding.... Did you use "last a foam" its the only foam I can find in 2" width. Its a core material on fiberglass supply.
We like the flat deck as well. Boat feels much bigger with the casting platform out. Did you make your front locker water tight? The only down side seems to be water getting in since you loose the drainage channels.
