Not for nothing, but, I had an issue with the downstream check valve in a primer bulb. I could pump the bulb up tight, but at some point the ball would stick cutting fuel flow off. I was seeing bubbles and some gas through the in line filter but motor wouldn't stay running. Replaced the bulb and haven't had a problem since.
