Here's my thoughts.
Remove the down stream side of primer ball, squeeze, if it flows put back in line.
Remove the gas supply line at the motor, squeeze the ball again, if flow re install the gas hose. Then go to the under cowl filter, repeat.
In other words start at some point in the fuel circuit and test down steam or up stream. I'm pretty sure it"s some thing simple.
Ed
