Old 06-19-2018, 10:26 AM
Make sure there is some support to keep the tank level. They may have put it in there to keep the tank from see-sawing. (Didn't see any support under the tank). Good luck!
If you look closely you can see the plywood that the tank is mounted to, so I think I'm good there. I'll replace the tank most likely at the end of the season and probably do a new board there as well.
