Thread: 1973 23 project
Old 07-20-2018, 10:44 AM
Oldboat Oldboat is offline
Default Drain
Capt Chuck makes a good point. When I took my step/fish box out there was a pocket of about 2 gallons of water that the foam was blocking from draining, it was nasty black water. The other thing I found is when the last tank was foam in foam got past tank board support and was blocking water from draininin properly along keel. I think at this point I’m going to just put a drain in out the bottom front of anchor box were door use to be since it will be above deck since I took step out . I am taking door out for anchor locker and moving it on top of deck as others have done. This will make it possible to when I rinse anchor locker to have water run out on deck no worry about issues down the road. I will create channel still in bow along keel so water will drain don’t won’t not xtra weight and lot water back in there. Will post pics when done
