Old 08-15-2018, 11:33 PM
Jared Jared is offline
Haven’t posted in a while, a Lot has been going on keeping me busy with work/family/fishing but have been making a little progress on the boat. The floor is pretty far along, just need a little more glass work on the starboard side and then some final fairing. Since the last update on the floor:
-glued the meranti ply down using epoxy thickened with cabosil. The wood I removed was rotten under the lip toward the gas tank opening, I was able to chisel out all the rotten spots and cut a piece of ply to fit in between the 2 skins. I didn’t want a straight line of a joint in that spot on the deck, although in hindsight I don’t think it mattered anyway so I cut that sawtooth pattern into the joint. It was late and made me feel better.
-after prepping and prefitting the top skin a few times I had a low spot on the ends. I built it up with a couple layers of biax now to save some fairing later.
-top skin glued down with more thickened epoxy. It was hot and had to mix a lot of resin, had to call in reinforcements to make sure I could get everything how I wanted it before any resin started to kick.
-seam between glued down skin and deck ground out a couple inches each way and to put a couple layers of 10 oz plain weave.
-port side filled crack all the way around top skin bonded back on with thickened resin. This will be sanded smooth before 2 plies of glass goes down. Starboard side has ply glued down and cured, now top skin curing.
-this is where I left it tonight. The port side has the 2 layers of 10 oz plain weave on, needs a bit of fairing. The starboard side is sanded and ready for the fiberglass.
