Old 08-20-2018, 09:23 AM
Jared Jared is offline
Got the starboard side fiberglass laid down, now hoping to pull the boat to work sometime soon. My compressor is too small to run a 16” board sander I have, need the bigger one at work to do a quick job of fairing and sanding the floor repairs.
In the meantime, made a gas tank. This one is just under 52 gallons, made from 1/8” 5052 aluminum. Pressure tested ok, now working on getting the fiberglass slats I made earlier glassed in at the correct height underneath the tank to support it. The nice part about shortening the tank a bit lengthwise and pushing it forward for weight is now all the space behind it will be a new storage compartment eventually.
I want to either coal tar epoxy the tank before the final installation or some other kind of corrosion preventative measure, any ideas? The only DIY coal tar epoxy materials I could find online looked like it was way more material that I need, I didn’t want to waste the extra money. Might try to find a local company to coat it.
