Old 08-20-2018, 11:13 PM
Jared Jared is offline
Originally Posted by crsavage1 View Post
Any thoughts? Additionally I was considering a stock fuel tank from RDS rather than a custom one. The stock ones will fit fine but curious if there is a specific reason to have one custom made? I know the bottom of the belly section is wider than the one that came out of mine, but I was going to lay down a composite bed for the tank to sit on anyhow for air circulation and to allow the areas to drain to the bilge so I can essentially raise the tank and still have it fit. Anyone have experience with one of the pre-made RDS tanks? They are constructed of .90 5052 rather than .125 5052 which was one of the only differences I noted. Thanks for any insight...
I just made a new tank, I went with .125 due to the cost of materials only being $25 more when I bought the aluminum. The original 70 gallon tank I had pulled out of mine was .090 5052, it was 30 years old. If it weren’t for the foam around the tank getting water logged and holding moisture up against it causing pitting it would have went back in.
