Old 08-27-2018, 08:07 PM
I am well versed at this task and can tell you 1/32 shouldn’t be an issue. There is two steps on the gaskets. First you have to remove the old glazing behind the glass and frame and replace it with foam glazing tape, install glass and then the gasket. Letting the gasket get warm in the sun helps installation as well as some weak soapy water in a spray bottle. Pm me your phone number and I’ll explain the task in more finer a detail.
