Old 09-05-2018, 09:31 AM
Not sure of your space limitations. Using a bottle jack could you hold a straight edge or carpenters level on the keel. Then using a small adjustable square placed on the level measure the vertical distance to where the square touches the transom and the corresponding distance along the keel. Hence the two sides of a right triangle. The angle would be the arctan of the short keel dimension divided by the vertical dimension. For instance the arctan of 2.9” divided by 10” is 16.2 degrees. Rusty on your trignometry, post a pix with dims. One of us will help.
