Old 09-10-2018, 05:11 PM
dginge dginge is offline
When they rebuilt my floor they left it raw on the bottom so that if it got wet it would dry. Most of the spots prone to dampness was epoxied. I hear that this method isn’t the best but my floor is solid. I think it was done in 2005
I have not had the liner out of my '76 23 Sceptre but I have cut the decks out. The PP was between 1/4 and 1" thick on the stringer tops - still surprisingly well bonded to the fiberglass lower skin of the deck. It appears that there is also PP between the liner and hull where they are screwed together under the rubrail. I was able to get a chisel under the putty and break larger chunks off of the stringer tops (got most of it) and ground on the rest to remove. I probably could have left the lower deck skin in and just replace the core and top but decided to do the whole tamale.
