They are easy to replace with the flaring tool. Both my blocks were solid and look great when I remove them last year so inless u had water getting in there u should be good. 2 new brass tubes 5200 and another person to hold bolt on the other side of flairing tool and your done in 2 hours. Leave no more than 1/8 inch on side u flair, to long and flange will crack. The flairing tool u get may be to short pick up rod at Home Depot and trim to correct length . Might as well do your fishbox drain while your at it
