Old 10-25-2018, 12:33 PM
Thanks Moose, Mitch and DonV for your suggestions-
Right now I am leaning towards increasing the transom from 20” to 22” Why 22” and not 25”? In my 42 years of use, with a Hermco splashwell, and particularly only lake-usage now, the 20” has served me quite well. I only anchor from the bow and keep the stern towards the beach. I have about 2” of clearance now from the ETEC to the transom. A 22” transom with the splashwell drain plug installed, would provide more margin when the heavies are sitting in the stern at anchor. With 22” I can also keep my mechanical steering and avoid a 5” ETEC driveshaft extension.
The next step is building or locating an engine stand for the 418# ETEC.
When I was replacing my transom, I planned on raising it 2-1/2". When I cut the core, I left an extra inch at the top with intentions of trimming it down to 2-1/2". Didn't get trimmed so I have 3-1/2" more than before. All is fine except the hydraulic steering fittings will hit if I try to raise it all the way. I have another inch to raise the new motor, (old one took a fatal crap), and that should correct that issue. You'll like having the extra height whatever you end up with.
